If EXISTS C:SquirrelSCSI C:SquirrelSCSI EndIf Set SCSIUpdate 1 If EXISTS C:IDEFix C:IDEFix Set SCSIUpdate 0 EndIf If EXISTS SYS:Expansion/XSurfIDE Set SCSIUpdate 0 EndIf If EXISTS SYS:Prefs/Env-Archive/NOSCSIUPDATE Set SCSIUpdate 0 EndIf If $SCSIUpdate EQ 1 SetPatch QUIET Else SetPatch SKIPROMUPDATES "scsi.device" QUIET EndIf Unset SCSIUpdate
LoadModule "DEVS:NCR scsi.device" DEVS:scsi.device L:Shell-Seg REVERSE NOREBOOT SetPatch SKIPROMMODULES "NCR scsi.device,scsi.device,shell" QUIET
C:val FastExec REBOOT NOEXEC PATCH FASTSSP FASTVBR FASTMEM FASTINT CACHE 0x00000001 If EXISTS C:SquirrelSCSI C:SquirrelSCSI EndIf LoadModule "DEVS:NCR scsi.device" DEVS:scsi.device L:Shell-Seg REVERSE NOREBOOT SetPatch SKIPROMMODULES "NCR scsi.device,scsi.device,shell" QUIET C:StackAttack C:Version >NIL: C:AddBuffers >NIL: DF0: 15 FailAt 21 C:MakeDir RAM:T RAM:Clipboards RAM:ENV RAM:ENV/Sys C:Copy >NIL: ENVARC: RAM:ENV ALL NOREQ Resident >NIL: C:Assign PURE Resident >NIL: C:Execute PURE C:CardReset Assign >NIL: ENV: RAM:ENV Assign >NIL: T: RAM:T Assign >NIL: CLIPS: RAM:Clipboards Assign >NIL: REXX: S: Assign >NIL: PRINTERS: DEVS:Printers Assign >NIL: KEYMAPS: DEVS:Keymaps Assign >NIL: LOCALE: SYS:Locale Assign >NIL: LIBS: SYS:Classes ADD Assign >NIL: HELP: LOCALE:Help DEFER Assign >NIL: DOpus5: Sys:Opus5 Assign >NIL: JPEGTMP: RAM:T copy sys:prefs/env-archive/sys/def_ram.info Ram:disk.info C:Fblit BindDrivers C:Mount >NIL: DEVS:DOSDrivers/~(#?.info) C:LoadMonDrvs SetEnv Language "english" SetEnv Workbench $Workbench SetEnv Kickstart $Kickstart UnSet Workbench UnSet Kickstart ;FastIPrefs NOWAIT NOGAUGE LOCKPEN NOFULLWB; NoMemPatch C:AddDataTypes REFRESH QUIET C:IPrefs C:ConClip Path >NIL: RAM: C: SYS:Utilities SYS:Rexxc SYS:System S: SYS:Prefs SYS:WBStartup SYS:Tools SYS:Tools/Commodities SYS:System/REXXMast >NIL: IF EXISTS S:User-Startup Execute S:User-Startup EndIF StackAttack AUTO Resident Execute REMOVE Resident Assign REMOVE C:WBCtrl IMT=ICONFAST C:LoadWB SIMPLEGELS ;C:Ftext mount pc0: EndCLI >NIL:
@11MASTEr, post #3
