#include <proto/exec.h> #include <proto/dos.h> #include <proto/intuition.h> #include <intuition/intuition.h> #include <string.h> #include <stdio.h> #include <stdlib.h> #include <time.h> struct Screen* APP_pubscreen = NULL; struct Window* APP_window = NULL; LONG APP_signals; int main(int argc, char **argv) { if (argc <= 1) { printf("To use msSimpleCron you must give two parameters:\n"); printf("- first: the command to execute ex. 'execute sys:tools/my.scrip't or 'sys:tools/calculator' etc.\n"); printf("- second: is the time of delay in miliseconds, ex. 5000 for 5 seconds etc.\n"); printf("for example: msSimpleCron 'execute my.script' 10000 <-- will run my.scipt every 10 seconds."); return 0; } LONG curr_time = clock(); LONG start_time = curr_time; LONG elapsed_time = 0; LONG time_total = 0; LONG delay = argv[2]; if (!(APP_pubscreen = LockPubScreen(NULL))) return 20; // --- create window --- APP_window = OpenWindowTags( NULL, WA_Left, 0, WA_Top, 0, WA_Width, 0, WA_Height, 0, WA_Flags, WFLG_ACTIVATE, WA_PubScreen, (ULONG)APP_pubscreen, TAG_END); if (!APP_window) return 20; // enter main loop BOOL is_loop = TRUE; while(is_loop) { curr_time = clock(); time_total = (curr_time - start_time); if (time_total - elapsed_time >= delay) { elapsed_time = clock(); system(argv[1]); } if(SetSignal(0L, APP_signals) & APP_signals) { struct IntuiMessage *imsg; while( imsg=(struct IntuiMessage *)GetMsg(APP_window->UserPort) ) { ReplyMsg((struct Message *)imsg); } } } }
@mateusz_s, post #1
@snajper, post #2
@asman, post #6
