@TechNineWonder,
post #30
@Chick please don't spread false information's. It is not that 50% of the cards are send untested or non working, percentage is more closer to 80%. Tnx.
Ok back to the subject, Quad, for testing the card I need USB blaster, TeamViewer and Quartus 13.1 installed. We will debug it online because there are huge chances that there is nothing with the card, only connection to Amiga motherboard is not ensured properly. As you probably know regarding A600 this is pure hack and if there is 0.1mm difference on soldered MC68K card won't work properly. With USB blaster I can see exactly where problem is and tell you what to do. I can send you another card and it still won't work because same problem will remain. About guarantee and how is functioning on my side, use hammer break the card completely and I ll send you another one, also if you do that in next 30 years and I m alive I ll send you another one. So join us on chat tonight and we will see what we can do in best interest for you.
