@Rafael/ARMO, post #2
@mateusz_s, post #3
@asman, post #5
@mateusz_s, post #7
if (losuj() = 0)
} @asman, post #5
Jeśli ten algorytm wybiera tylko parzyste liczby przez ileś tam początkowych losowań to zawsze będzie zero w Twoim przypadku
@asman, post #8
if (losuj() = 0)
}if (funkcja()==0)
if (!funkcja())
@MDW, post #14
@asman, post #8
void SYS__run(void)
// Signal mask for window.
ULONG signal_mask = ( 1 << SYS__window->UserPort->mp_SigBit );
char debug_string[32];
UBYTE current_buffer = 0;
srand(time(NULL));
// Enter main loop.
while (G_io__prefs.is_loop)
// Enter Window Message Loop - handle messages and events.
if(SetSignal(0L, signal_mask) & signal_mask)
struct IntuiMessage *imsg;
while( imsg = (struct IntuiMessage *)GetMsg(SYS__window->UserPort) )
switch (imsg->Class)
case IDCMP_MOUSEMOVE:
break;
case IDCMP_RAWKEY:
break;
ReplyMsg((struct Message *)imsg);
// If using AGA make c2p conversion to the output buffer and display.
if (SYS__is_aga)
// Rendering the game.
G_run();
// Chunky to planar conversion.
c2p1x1_8_c5_040(G_io__prefs.view_buffer, SYS__buffer[current_buffer]->sb_BitMap->Planes[0]);
// Swap Buffers with sync.
if (G_io__prefs.is_sync)
if (!SYS__safetochange)
while (!GetMsg(SYS__display_port)) WaitPort(SYS__display_port);
SYS__safetochange = TRUE;
if (ChangeScreenBuffer(SYS__screen, SYS__buffer[current_buffer]))
SYS__safetochange = FALSE;
// Switch buffers.
current_buffer ^= 1;
else
// Puting into screen display the otherone bitmap.
SYS__screen->RastPort.BitMap = SYS__buffer[current_buffer^1]->sb_BitMap;
SYS__screen->ViewPort.RasInfo->BitMap = SYS__buffer[current_buffer^1]->sb_BitMap;
// Sync with the monitor.
RethinkDisplay();
// Setting the game output buffer adress into one of the system bitmaps.
// Now the geme will render directly into one of the system bitmaps.
G_io__prefs.view_buffer = SYS__buffer[current_buffer]->sb_BitMap->Planes[0];
G_run();
// Switch buffers.
// Show some debug info.
if (G_io__prefs.is_debug)
sprintf(debug_string, "fps: %d dt: %.4f sync: %d", rand()%2, G_io__prefs.delta_time, G_io__prefs.is_sync);
Move(SYS__window->RPort, 0,20);
Text(SYS__window->RPort, (CONST_STRPTR)debug_string, strlen(debug_string));
}int a = ((rand()%20) < 10);
@teh_KaiN, post #15
żeby nie było - przypisanie wartości do wywołania funkcji zawsze skończy się błędem w c/cpp.
Warto mieć włączone -Werror co by kompilator traktował warningi jako errory.
A co do niewidoczności wykrzyknika - może wypadałoby zainwestować w jakiś lepszy schemat kolorowania składni, co by operatory miały inny kolor niż nawiasy. Albo fonta zwiększyć. ;)
@Phibrizzo, post #18
@mateusz_s, post #16
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
int main(void)
srand(time(NULL));
for (int i = 0; i < 20; ++i)
sprintf(debug_string, "fps: %d \n", rand() & 1);
printf("%s", debug_string);
return 0;
Dlatego wolę własną implementacje która ma jakiś własny kontekst.nie ma problemu z mieszaniem wywołań. I to też polecam zrobić.
@MDW, post #14
if( ! funkcja() )
@MDW, post #17
@mateusz_s, post #24
