WBStartup DEFTYPE .w ;The interlaced bitmap BitMap 0,640,512,8 ;The original bitmap BitMap 1,640,512,8 LoadBitMap 1,"image.iff",0 ;Convert the original bitmap to interlaced Use BitMap 0 for i = 0 to 255 BlockScroll 0,i*2,640,1,0,i,1 BlockScroll 0,1+i*2,640,1,0,i+256,1 next ;Configure two copper lists for i = 0 to 1 InitCopList i,44,DispHeight,$10000 + $1000 + $100 + $8,8,256,0 DisplayBitMap i,0,0,i*256 DisplayPalette i,0 next BLITZ ;Repeatedly recreate the display and toggle the LOF bit SetInt 5 VP = Peek.w($DFF004) X=1-X if X=0 CreateDisplay 0 VP = VP BITSET 15 else CreateDisplay 1 VP = VP BITCLR 15 endif Poke.w $DFF02A,VP End SetInt While Joyb(0)+Joyb(1) = 0 Wend End
; Setup the screen for a hires laced display. This is used for the credits screens
#BPLCON0=$100 ; Bitplane control register
#BPLMOD1=$108 ; Bitplane modulo
#BPLMOD2=$10A ; Bitplane modulo
#bitmapsize=768
#Modulo=(((#bitmapsize-320)/8)-2)*2
BitMap 0,320,256,5 ; Game screen. Lowres 32 colour
BitMap 1,320,256,5 ; Intro screens
BitMap 2,640,256,4 ; Title Screen
BitMap 3,#bitmapsize,512,3 ; Custom copper controlled hires-laced display for credits
; Lets build our own copperlist
cop$=Mki$(#BPLMOD1)+Mki$(#Modulo)
cop$+Mki$(#BPLMOD2)+Mki$(#Modulo)
cop$+Mki$(#BPLCON0)+Mki$($b004) ; BPLCON0 : Bit number:
; 15 - Hires
; 14, $13, $12 bitplanes set (011 here for 3 bitplanes)
; 11 - Ham mode Off
; 10 - Dual playfield Off
; 09 - Composite colour mode off
; 08 - Genlock Audio Enable off
; 07 to bit 4 - Unused, set to 0
; 03 - Lightpen off
; 02 - Interlace ON
; 01 - External Synchronization Enable off
; 00 - Unused
; Buffer for animation
InitCopList 3,41,256,$513,8,8,-3 ; $11903 ; 8 colour hires laced display
DisplayUser 3,0,cop$ ; Set our copperlist
DisplayAdjust 3,768,-8,-8,-32,32 ; and adjust the display accordingly
CreateDisplay 3
Use BitMap 3
DisplayPalette 3,1
SetInt 5
If Peek($df004) <0
DisplayBitMap 3,3,3,0
Else
DisplayBitMap 3,3,3,1
EndIf
End SetInt
Blit 1,0,20
DisplayBitMap 3,3
End@mateusz_s, post #1
@Solo Kazuki, post #2
@mateusz_s, post #3
@cholok, post #6
@cholok, post #8
@cholok, post #10
WBStartup
#BPLCON0 = $100
#BPLMOD1 = $108
#BPLMOD2 = $10A
#BPLCON0_MASK = %1000000000010100 ; binary
#MODULO = 80 ; line modulo for hires laced 256
; init bitmap space
BitMap 0,640,512,8
; loading 640x512 x 256 colors image
LoadBitMap 0,"dh1:test-hires-256.iff",0
BLITZ
; configure two copper lists
; custom set to -3, because 3 instructions $100+$108+$10A
cop$ = Mki$(#BPLCON0) + Mki$(#BPLCON0_MASK)
cop$ + Mki$(#BPLMOD1) + Mki$(#MODULO)
cop$ + Mki$(#BPLMOD2) + Mki$(#MODULO)
; copper nr 0 for displaying only odd lines
InitCopList 0, 44, DispHeight, $10000 + $1000 + $100 + $8, 8, 256, -3
DisplayUser 0, 0, cop$
DisplayBitMap 0,0,0,0
DisplayPalette 0,0
; copper nr 1 for displaying only even lines
InitCopList 1, 44, DispHeight, $10000 + $1000 + $100 + $8, 8, 256, -3
DisplayUser 1, 0, cop$
DisplayBitMap 1,0,0,1
DisplayPalette 1,0
; using interupt 5 to display and toggle two copper lists
counter.w = 0
SetInt 5
counter = 1 - counter
If counter = 0
CreateDisplay 0
Else
CreateDisplay 1
EndIf
End SetInt
MouseWait
EndSetInt 5
If counter = 0
CreateDisplay 0
VP BitSet 15
Else
CreateDisplay 1
VP BitClr 15
EndIf
Poke.w $DFF02A, VP
End SetInt@mateusz_s, post #11
@cholok, post #12
Screen 0,0,0,640,512,8,-28668,"TEST",0,1 BitMap 0,640,512,8 LoadBitMap 0,"dh1:test-hires-256-info.iff",0 Use Palette 0 ShowBitMap 0 MouseWait
@mateusz_s, post #13
Statement ResizeWidth{index.l,amount.l,xadjust.l}
diwstrt.l = xadjust*8
diwstop.l = diwstrt + amount*8
dUfstrt.l = Int(diwstrt/2)
dUfstop.l = Int(diwstop/2)
DisplayAdjust index,amount,dUfstrt,dUfstop,diwstrt,diwstop
End Statement
Where:
- Index is the copper list
- Amount is the amount of pixels to increase or decrease the width by (multiples of 8)
- XAdjust is the amount to move it left or right by (multiples of 8) @cholok, post #15
@cholok, post #15
