[#1] Promodule help
Hello,
I have bought the promodul, but without cable between cd32 and promodule and without power supply. Can someone tell me what are parametres of the power supply (may I use classic a500 power supply??) and do you have a plan or description of the cable between promodule and cd 32? Thanx for answer Aper (Cziechy
[#2] Re: Promodule help
@aper, post #1
I have never had Promodule (and CD32 too ;)), but I have found some tips and photos of Promodule in the Internet...
hmmm, have you got the cable between CD32 and Promodule? I think these devices are connected with special socket, and CD32 is standing on Promodule. Promodule has the socket for standard Amiga power supply, so you can use A500 power supply. A500 power supply is better than other, because this device has the biggest power among power supplies for desktop amigas. Promodule has jumpers to switch power source beetwen internal and external - I think you must use only one power supply - connected to Promodule or CD32, and of course switch it properly.
Greetings for Czech Brothers in Amiga ;)
[#3] Re: Promodule help
@aper, post #1
Thanx!You are right, there is a special socket for conection cd32 - promodule. So special, that I am afraid I cant make it home. I wrote an email to the manufacturer, so I will see...
But the power supply from the a500 works great...
pozdrawiam amigistow w Polska
[#4] Re: Promodule help
@aper, post #3
Hello!i have promodule working with cd32. A500 power works only as a additional power supplier.,so its obligatory to use cd32 supply always,cos cd32 won´t start, even when you change jumpers inside promodule.You can make around by replacing cable from cd32 supply to A500 suply.its gonna be much better if you have lot of hardware inside promodule.check
www.iansteadman.co.uk -massive article about supplier tuning
About connector -I can only make you a very precise pics of mine.You´ve got to hire an electrisian :)
