[#6]
Re: Problem z uruchomieniem Pega.
@Kitech,
post #1
Witam.
Doszły nowe dane do analizy (nullmodem i Hyperterminal).
1. Zwiecha - nie pojawia się nawet OF (monitor mówi: "No signal"):
PegasosII Boot Strap (c) 2002-2005 bplan GmbH (BUILD 20051216202806)
Running on CPU PVR:80020101
Enable L1 ICache... Done.
Clean/Flush Block enabled
Reading ICS9248 : 84EFFF3FFFFF Done.
Setting Front Side Bus to 133MHz... Done.
Memory has not changed
Configuring Memory
Memory Config Done
Configuring PCI0... Done.
Configuring PCI1... Done.
Configuring ETH... Done.
Releasing IDE reset ... Done.
Configuring Legacy Devices
Initializing KBD... Done.
Testing 20000000 Bytes, Pass: 00000000 Failed: 00000000
RAM TEST (fill random)... FAILED.
ADR : 1B626738
VAL : 44E5FA70
VAL : 44C5FA70
1B626730 : FA061222 F66844B3 44E5FA70 BD39F1E9
1B626740 : 7C972E6E F398790F 9D684D9C 6FB6C3A5
1B626750 : 770BC37A 6FED972B E27AA788 E874F521
1B626760 : 95029D46 A82C7B07 16D6B434 B88AC25D
1B626770 : CB3B47D2 768BC0A3 6F44DFA0 F2362759
1B626780 : A8E20F1E 180FC3FF 62A855CC 7398E015
1B626790 : 719BFF2A EBA6A11B 90EB02B8 21346891
1B6267A0 : CC52E3F6 070433F7 2CA99264 4C25FCCD
1B6267B0 : 92C14982 3D3E1893 539F70D0 402298C9
1B6267C0 : 0DBE7BCE F327AAEF 81D2C9FC B532F885
1B6267D0 : AA4A86DA DD6E070B 0B8089E8 A12F9801
1B6267E0 : F35A36A6 847408E7 49C85C94 A4FCB33D
1B6267F0 : 5C631732 29EE4C83 E618AE00 11864639
1B626800 : 28A7747E 6C3F2DDF 705AAA2C 407C0CF5
1B626810 : 7B425A8A C392C8FB 2BDE3D18 BCCD8371
1B626820 : 5BF39556 B4BAF9D7 BF0612C4 76E5E5AD
Entering IKARUS low level console
2. Wszystko się odpaliło bez problemu po resecie (nawet brak zwiechy na motylku:
Reading ICS9248 : FAEFFF3FFFFF
Configuring Memory
QZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZFMemory Config
Done
RAM TEST (fill random)... Done.
SmartFirmware:
cpu0: PowerPC,74x7 CPUClock 999 Mhz BUSClock 133 Mhz (Version 0x8002,0x0101)
no/bad nvramrc - performing default startup script
channel 0 unit 0 : ata | WDC WD800JB-00JJC0 | 05.01C05
ATA device not present or not responding
channel 1 unit 0 : atapi | HL-DT-STDVD-ROM GDR8161B | 0100
EMULATION INT HANDLER ENTERED WITH:
INT NO: 15
EAX=0003 EBX=1111 ECX=2222 EDX=3333 ESP=0000 EBP=5555 ESI=6666 EDI=7777
AX=4E08 BX=C405 CX=0003 DX=102A SP=6C1C BP=5555 SI=5C6B DI=7777
DS=C000 ES=BAD0 SS=C000 CS=F000 IP=FE15 NV UP -- PL ZR NA PE NC
CS:IP = F4 FS=BAD4 GS=BAD5C4CA C000 0244 3000 0000 01B4 ABD5 0200
UNHANDLED INT 10 FUNCTION 0007 WITHIN EMULATION
VM using 2127437 x86 cycles for GFX init
auto-booting...
OF_ParseArgs: bootargs
ReadArgs: rda 0x17ff768 template =
ags/K,LogLevel/N,MaxHits/N,FullHit/S,BackTraceDepth/N,BootDevice/K,LogServer/S,N
oL2Cache/S,NoL3Cache/S,RamDebug/S> array = 0x17ff728
ReadArgs: line = "ramdebug"
->unquoted "ramdebug"
->nothing
ReadArgs: error = 0, rda = 17ff768
FreeArgs: args = $17ff768
FreeArgs: DAList = $5cb034
QDebugFlags 0x8 EDebugFlags 0x80010000 DDebugFlags 0x0
Driver_VIA8231: MyBoardNode 0x5cbb34
Driver_VIA8231: VendorID 0x1106 DeviceID 0x8231
Driver_VIA8231: BridgeID 0x0 BusID 0x0 DevID 0xc IOBase 0xfe000000
Driver_VIA8231: VIA 8231 found
Driver_VIA8231: done
CPU_EnableL2Cache(Size 256 kb)
CPU_EnableL2Cache: L2CR 0x0
CPU_EnableL2Cache: MyCPU 0 CPUType 0x8002 CPURevision 0x101
CPU_EnableL2Cache: done
Proszę o komentarz (ja widzę tylko, że coś jakby z RAMem)!
3. Zrobiłem właśnie Reboot z MOSa i OF bez problemu, za to zwiecha na motylku:
Configuring Memory
Memory Config Done
Initializing KBD...
Memory Test skipped (Warmboot detected)
SmartFirmware:
INT NO: 15
VM using 2127411 x86 cycles for GFX init
auto-booting...
->nothing
Ostatnia modyfikacja: 17.08.06 18:06
