[#1] help in ppc-warp3d tests :)
Hi all. Qeustion to classic ppc/video board owners with warp3d support.
Can you provide in this topic, info about your system, and gears-ppc,gears-ppc-small and geard-ppc-window fps result ? It is need it for me , becouse all want to know, how can be provide best speed for this kind of amiga configs. Best choice is it (for me for example)
amiga: a1200, bppcx266/060x66, mediator-sx/voodoo3 3000.
gears-ppc - 27 fps
gears-ppc-small - 29,5 fps
gears-ppc-window - 29 fps
btw, of course i am interesting in bvision tests too, other pci boards (like grex and prometheus). thanks all.
[#2] Re: help in ppc-warp3d tests :)
@kas1e, post #1
a1200 BPPC 603/210 (oscillator 50 MHz), 040/40 (oscillator 80 MHz), BVision
gears_ppc - 27-32 fps
gears_ppc-small - 32-34 fps (WB 1024x768 16 bit)
gears_ppc-window - 23-26 fps (WB 1024x768 16 bit)
[#3] Re: help in ppc-warp3d tests :)
@Andrzej Drozd, post #2
Andrzej, a czym się mierzy fps'y, to może i ja bym spróbował.
[#4] Re: help in ppc-warp3d tests :)
@Kitech, post #3
Po odpaleniu gears (jest w katalogu W3DDemo) nacisnij klawisz "f" i spisz najnizsza i najwieksza wartosc. Kolega wyzej podal dokladnie. Nie wiem, moze gears gdzies robi logi albo jest to srednia dwoch wynikow.
PS. Gdy bedziesz robil test, to wylacz np. limbid clocka i inne podobne, ruchome elementy, a np. MCP uniekatywnij na chwile za pomoca Exchange (w sumie biblioteka warp3d jest pod 68k i jak cos bedzie chodzilo w tle to wyniki moga byc zanizone).
PS2. Nie odpalaj gearsa w wersji 68k, bo moze zresetowac kompa. Mi padla walidacja :)
[#5] Re: help in ppc-warp3d tests :)
@Andrzej Drozd, post #4
Thx!
[#6] Re: help in ppc-warp3d tests :)
@kas1e, post #1
A1200 BPPC 603/200 040/30, BVision
gears_ppc - 25-28 fps
gears_ppc-small - 27-29 fps (WB 1024x768 16 bit)
gears_ppc-window - 21-24 fps (WB 1024x768 16 bit)
[#7] Re: help in ppc-warp3d tests :)
@Kitech, post #6
A4000 BPPC 604/210 060/50, VooDoo3 3000
gears_ppc - 36-37 fps
gears_ppc-small - 37-38 fps (WB 1024x768 16 bit)
gears_ppc-window - 38-39 fps (WB 1024x768 16 bit)
