[#2]
Re: A1200 problem z OS 3.9 - brak dysku, soft failure, etc.
@oldskull,
post #1
Dodatkowa ciekawostka. System uruchomiony z biblioteką 680040 ale z wyłączonym cache w bootmenu wstaje ale jest wyraźnie wolniejszy. Potem można ICache i DCache włączyć w SysInfo i różnica od razu jest widoczna. Może mam coś nie tak w S-S? (BB4).
SYS:C/LoadModule L:FastFileSystem L:RAM-Handler L:Shell-Seg DEVS:scsi.device LIBS:icon.library LIBS:workbench.library NOREBOOT REVERSE
SYS:C/SetPatch SKIPROMMODULES fs,icon,ram-handler,scsi.device,shell,workbench QUIET
; $VER: Startup-Sequence 45.4 (4.4.2001)
; Startup-Sequence for AmigaOS 3.9
; The following lines disable updating "scsi.device" for driver
; software where this could lead to failures. They also start
; IDEFix if installed.
; You can manually disable updating "scsi.device" by setting
; the environment variable "NOSCSIUPDATE" to something.
If EXISTS C:SquirrelSCSI
C:SquirrelSCSI
EndIf
;Set SCSIUpdate 1
;If EXISTS C:IDEFix
; C:IDEFix
; Set SCSIUpdate 0
;EndIf
;If EXISTS SYS:Expansion/XSurfIDE
; Set SCSIUpdate 0
;EndIf
;If EXISTS SYS:Prefs/Env-Archive/NOSCSIUPDATE
; Set SCSIUpdate 0
;EndIf
;If $SCSIUpdate EQ 1
; SetPatch QUIET
;Else
; SetPatch SKIPROMUPDATES "scsi.device" QUIET
;EndIf
;Unset SCSIUpdate
C:Version >NIL:
C:AddBuffers >NIL: DF0: 15
FailAt 21
C:MakeDir RAM:T RAM:Clipboards RAM:ENV RAM:ENV/Sys
C:Copy >NIL: ENVARC: RAM:ENV ALL NOREQ
Resident >NIL: C:Assign PURE
Resident >NIL: C:Execute PURE
Resident >NIL: C:SetEnv PURE REPLACE
Assign >NIL: ENV: RAM:ENV
Assign >NIL: T: RAM:T
Assign >NIL: CLIPS: RAM:Clipboards
Assign >NIL: REXX: S:
Assign >NIL: PRINTERS: DEVS:Printers
Assign >NIL: KEYMAPS: DEVS:Keymaps
Assign >NIL: LOCALE: SYS:Locale
Assign >NIL: LIBS: SYS:Classes ADD
Assign >NIL: HELP: LOCALE:Help DEFER
BindDrivers
C:Mount >NIL: DEVS:DOSDrivers/~(#?.info)
C:LoadMonDrvs
SetEnv Language "english"
SetEnv Workbench $Workbench
SetEnv Kickstart $Kickstart
UnSet Workbench
UnSet Kickstart
C:AddDataTypes REFRESH QUIET
C:IPrefs
C:ConClip
Path >NIL: RAM: C: SYS:Utilities SYS:Rexxc SYS:System S: SYS:Prefs SYS:WBStartup SYS:Tools SYS:Tools/Commodities
SYS:System/REXXMast >NIL:
SYS:C/MakeLink RAM:disk.info ENVARC:SYS/def_RAM.info SOFT
IF EXISTS S:User-Startup
Execute S:User-Startup
EndIF
Resident Execute REMOVE
Resident Assign REMOVE
C:LoadWB
EndCLI >NIL:
