[#1] Polish TrueType fonts
Hi,
I'd like to improve Polish TrueType font support in next AmiKit update.
Basically I need a truetype font that would look like this: http://bit.ly/1Gld3BG (VeraSans font) but with Polish support. Which font would you recommend?
Also, is a codeset file necessary to install Polish true type font? For example, when I am installing a Russian font (using TrueType FontManager), I have to add "Amiga-1251" codeset file to the font.
Dziękuję,
Jan
[#2] Re: Polish TrueType fonts
@AmiKit, post #1
Guess you could use some linux utf-8 truetupe font.
I found this, hope it is similar.
Regards
