dmesg | grep Adaptec [ 6.950328] scsi host4: Adaptec AIC7XXX EISA/VLB/PCI SCSI HBA DRIVER, Rev 7.0
sudo su echo "- - -" > /sys/class/scsi_host/host4/scan
lsscsi [4:0:2:0] disk QUANTUM LP52S 950509405 3.1 /dev/sdb [5:0:0:0] disk ATA WDC WD800JD-75MS 1E04 /dev/sda
sudo dd if=/dev/sdb of=quantum.img 0+0 records in 0+0 records out 0 bytes copied, 0,000200793 s, 0,0 kB/s
echo "1" > /sys/class/block/sdb/device/rescan
fdisk -l
fdisk -l /dev/sdb fdisk: cannot open /dev/sdb: No such file or directory
[ 1204.825590] scsi 4:0:2:0: Direct-Access QUANTUM LP52S 950509405 3.1 PQ: 0 ANSI: 2 CCS [ 1204.846324] scsi target4:0:2: Beginning Domain Validation [ 1204.861617] scsi target4:0:2: FAST-5 SCSI 4.0 MB/s ST (248 ns, offset 8) [ 1204.872052] scsi target4:0:2: Domain Validation skipping write tests [ 1204.872054] scsi target4:0:2: Ending Domain Validation [ 1204.875242] sd 4:0:2:0: Attached scsi generic sg1 type 0 [ 1204.889150] sd 4:0:2:0: [sdb] Unit Not Ready [ 1204.889156] sd 4:0:2:0: [sdb] Sense Key : Hardware Error [current] [ 1204.889160] sd 4:0:2:0: [sdb] <<vendor>>ASC=0x88 ASCQ=0x0 [ 1205.424685] sd 4:0:2:0: [sdb] Read Capacity(10) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE [ 1205.424690] sd 4:0:2:0: [sdb] Sense Key : Hardware Error [current] [ 1205.424696] sd 4:0:2:0: [sdb] <<vendor>>ASC=0x88 ASCQ=0x0 [ 1205.424701] sd 4:0:2:0: [sdb] 0 512-byte logical blocks: (0 B/0 B) [ 1205.424704] sd 4:0:2:0: [sdb] 0-byte physical blocks [ 1205.697022] sd 4:0:2:0: [sdb] Test WP failed, assume Write Enabled [ 1205.962274] sd 4:0:2:0: [sdb] Asking for cache data failed [ 1205.962281] sd 4:0:2:0: [sdb] Assuming drive cache: write through [ 1205.979333] sd 4:0:2:0: [sdb] Unit Not Ready [ 1205.979339] sd 4:0:2:0: [sdb] Sense Key : Hardware Error [current] [ 1205.979345] sd 4:0:2:0: [sdb] <<vendor>>ASC=0x88 ASCQ=0x0 [ 1206.000167] sd 4:0:2:0: [sdb] Read Capacity(10) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE [ 1206.000172] sd 4:0:2:0: [sdb] Sense Key : Hardware Error [current] [ 1206.000178] sd 4:0:2:0: [sdb] <<vendor>>ASC=0x88 ASCQ=0x0 [ 1206.027255] sd 4:0:2:0: [sdb] Attached SCSI disk [ 1750.141470] sd 4:0:2:0: [sdb] Unit Not Ready [ 1750.141475] sd 4:0:2:0: [sdb] Sense Key : Hardware Error [current] [ 1750.141480] sd 4:0:2:0: [sdb] <<vendor>>ASC=0x88 ASCQ=0x0 [ 1750.151849] sd 4:0:2:0: [sdb] Read Capacity(10) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE [ 1750.151854] sd 4:0:2:0: [sdb] Sense Key : Hardware Error [current] [ 1750.151859] sd 4:0:2:0: [sdb] <<vendor>>ASC=0x88 ASCQ=0x0 [ 1915.998833] sd 4:0:2:0: [sdb] Unit Not Ready [ 1915.998839] sd 4:0:2:0: [sdb] Sense Key : Hardware Error [current] [ 1915.998844] sd 4:0:2:0: [sdb] <<vendor>>ASC=0x88 ASCQ=0x0 [ 1916.009236] sd 4:0:2:0: [sdb] Read Capacity(10) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE [ 1916.009241] sd 4:0:2:0: [sdb] Sense Key : Hardware Error [current] [ 1916.009246] sd 4:0:2:0: [sdb] <<vendor>>ASC=0x88 ASCQ=0x0
sudo apt-get install amiga-fdisk-cross
amiga-fdisk-cross_0.04-15build1_amd64.deb
amiga-fdisk -l amiga-fdisk -l /dev/sdb Cannot open device /dev/sdb sudo amiga-fdisk -l /dev/sdb Error occured while reading RDB. sudo amiga-fdisk -l No valid RDB found... Creating new Rigid Disk Block geometry: 255 heads, 63 secs, 9726 cyl, 0 start Error occured while reading block 0. Segmentation fault
@pgru2, post #1
@Norbert, post #2
@pgru2, post #1
@Rafał A-3000, post #4
@pgru2, post #1
@stachu100, post #9
@Rafał A-3000, post #10
Jemu właśnie zależy by dane odzyskać
@stachu100, post #11
@pgru2, post #12
@stachu100, post #13
@stachu100, post #16
