[#21]
Re: AmigaAMP decoding engine 1.15
@Andrzej Drozd,
post #20
Ja też się nie znam na ortografii angielskiej powaga
======= External68k.readme
AmigaAMP external decoding engine for 68k 1.15 BETA
This is the AmigaAMP external decoding engine compiled for 68060. If
you are running AmigaOS on an emulator like AmigaForever / WinUAE or
Amithlon on a fast PC you can copy this file into AmigaAMP/Engines
replacing the the one that's currently in there.
In the AmigaAMP config tool this new engine will show up on the system
tab as "68k-Emu". Please don't use autodetect as this will not work.
The advantage of this engine over the built in mpega.library support
is that the equalizer acutally works and the visualisation is more
accurate as well.
======= End.
