[#1] mldoney - problem
działało działało aż się zapsuło - po uruchomieniu otrzymuje taki komunikat:
am Disk:mldonkey-2.5.22-morphos/mldonkey> mlnet
No sys:/.mldonkey/installer.ini found
Resolving [localhost] ...done
ascii: [ 5(0)(1)(0) d(1)(0)(0) i(3)(0)(0)(2)(0)(4)(0) t o t o(4)(0) t u t u(186)(147) b(16)(196) % (245)(17)(213)(212) @(224) r(160) X(237) ,(25)(4)(236) ,(25)(4)(18)(0)(0)(0)(12)(0)(0)(0)(0)(7)(0) 1 0 1 0 1 0 0(1)(0)(0)(0)(0)(0)(0)(0)(4)(0) 2 . 2 0(1)(0)(9)(0) 9 1 9 4 3 5 6 3 7(9)(0) 9 1 9 4 3 5 6 3 6(0)(6)(0) t r a t r a(0)(0)(0)(0)(0)(0)(0)(0)(0)(0)]
dec: [(53)(0)(1)(0)(100)(1)(0)(0)(105)(3)(0)(0)(2)(0)(4)(0)(116)(111)(116)(111)(4)(0)(116)(117)(116)(117)(186)(147)(98)(16)(196)(37)(32)(245)(17)(213)(212)(64)(224)(114)(160)(88)(237)(44)(25)(4)(236)(44)(25)(4)(18)(0)(0)(0)(12)(0)(0)(0)(0)(7)(0)(49)(48)(49)(48)(49)(48)(48)(1)(0)(0)(0)(0)(0)(0)(0)(4)(0)(50)(46)(50)(48)(1)(0)(9)(0)(57)(49)(57)(52)(51)(53)(54)(51)(55)(9)(0)(57)(49)(57)(52)(51)(53)(54)(51)(54)(0)(6)(0)(116)(114)(97)(116)(114)(97)(0)(0)(0)(0)(0)(0)(0)(0)(0)(0)]
s = s2
Fatal error: exception Assert_failure("src/daemon/common/guiEncoding.ml", 1102, 4)
snoopium podaje (z niestandardowych rzeczy) tylko ze program nie mógł otworzyć gg:lib/ocaml/ld.config
może ktos wie jak to naprawić ?
[#2] Re: mldoney - problem
@rzookol, post #1
To się dzieje tylko wtedy jak przechodzisz z Linuksa na MorphOSa, tylko wtedy jest cofany czas na 1999 rok i tylko wtedy tak się właśnie mldonkey zachowuje. Ustaw zegarek a będzie dobrze
[#3] Re: mldoney - problem
@grxmrx, post #2
dzięki - już działa
