./configure
make all-recursive make[1]: Wchodze katalog `/home/sofcik/temp/lame-3.92' Making all in mpglib make[2]: Wchodze katalog `/home/sofcik/temp/lame-3.92/mpglib' source='common.c' object='common.lo' libtool=yes depfile='.deps/common.Plo' tmpdepfile='.deps/common.TPlo' depmode=gcc /bin/sh ../depcomp /bin/sh ../libtool --mode=compile m68k-amigaos-gcc -DHAVE_CONFIG_H -I. -I. -I.. -I../include -I. -I../libmp3lame -I.. -O3 -fomit-frame-pointer -ffast-math -funroll-loops -m68020-60 -m68881 -Wall -pipe -c -o common.lo `test -f common.c || echo './'`common.c ../libtool: line 1: print: command not found ../libtool: line 1: print: command not found ../libtool: line 1: print: command not found ../libtool: line 1: print: command not found ../libtool: line 1: print: command not found ../libtool: line 1: print: command not found ../libtool: line 1: print: command not found ../libtool: line 1: print: command not found ../libtool: line 1: print: command not found ../libtool: line 1: print: command not found ../libtool: line 1: print: command not found ../libtool: line 1: print: command not found ../libtool: line 1: print: command not found ../libtool: line 1: print: command not found ../libtool: line 1: print: command not found ../libtool: line 1: print: command not found ../libtool: line 1: print: command not found ../libtool: line 1: print: command not found ../libtool: line 1: print: command not found ../libtool: line 1: print: command not found ../libtool: line 1: print: command not found ../libtool: line 1: print: command not found ../libtool: line 638: print: command not found make[2]: *** [common.lo] Błąd 1 make[2]: Opuszczam katalog `/home/sofcik/temp/lame-3.92/mpglib' make[1]: *** [all-recursive] Blad 1 make[1]: Opuszczam katalog `/home/sofcik/temp/lame-3.92' make: *** [all] Blad 2
@Softfailur, post #1
./configure
> make all-recursive
...właśnie dlatego, że libtool byłby wzięty natywny a nie ten z binutils od kroskompilatora. To samo będzie dla ld, bibliotek, itd.
@Jacek Rzeuski, post #2
