@Krashan, post #30
; ; QOA decoder ;============================================================================== ; STEREO DECODING STRATEGY ; ; Stereo QOA files have interleaved slices in LR order. Decoding them in order ; means LMS state has to be swapped for each slice. To avoid this, there are ; two passes over a frame. The first pass loads L channel LMS state then ; decodes only even slices and stores audio samples at output buffer offset 0, ; advancing 4 bytes after each sample. The second pass loads R channel LMS ; state, then decodes only odd slices and stores audio samples at output buffer ; offset 2, advancing 4 bytes after each sample. ;============================================================================== ;============================================================================== ; Decodes QOA mono frame to a buffer. ; INPUTS: ; d0 - number of slices available in the frame buffer (1 to 256 including) ; a0 - frame buffer ; a1 - output buffer ;============================================================================== XDEF _DecodeMonoFrame _DecodeMonoFrame: MOVEM.L d2-d7/a2-a6,-(sp) SUBQ.L #1,d0 LEA sampoff,a2 MOVE.W #0,(a2) MOVE.W d0,d7 ; slice counter MOVEA.W (a0)+,a2 ; loading LMS history MOVEA.W (a0)+,a3 MOVEA.W (a0)+,a4 MOVEA.W (a0)+,a5 MOVE.L (a0)+,d2 ; loading LMS weights MOVE.L (a0)+,d3 nextslice: LEA dequant(pc),a6 ; pointer to lookup table MOVE.L (a0)+,d0 ; the first half of slice ; MOVE.L (a0)+,d1 ; the second half of slice SWAP d7 BSR.S slice ; decode slice SWAP d7 DBF d7,nextslice MOVEM.L (sp)+,d2-d7/a2-a6 RTS ;============================================================================== ; Decodes QOA stereo frame to a buffer. ; INPUTS: ; d0.w - number of slices per channel available in the frame buffer (1 to 256 ; including) ; a0.l - frame buffer ; a1.l - output buffer ;============================================================================== XDEF _DecodeStereoFrame _DecodeStereoFrame: MOVEM.L d2-d7/a2-a6,-(sp) SUBQ.L #1,d0 LEA sampoff,a2 MOVE.W #2,(a2) MOVE.L a0,-(sp) MOVE.L a1,-(sp) MOVE.W d0,-(sp) ; L channel pass MOVE.W d0,d7 ; slice counter MOVEA.W (a0)+,a2 ; loading LMS history MOVEA.W (a0)+,a3 MOVEA.W (a0)+,a4 MOVEA.W (a0)+,a5 MOVE.L (a0)+,d2 ; loading LMS weights MOVE.L (a0)+,d3 LEA 16(a0),a0 ; skip R channel LMS state nextleft: LEA dequant(pc),a6 ; pointer to lookup table MOVE.L (a0)+,d0 ; the first half of slice ; MOVE.L (a0)+,d1 ; the second half of slice SWAP d7 BSR.S slice ; decode slice SWAP d7 ADDQ.L #8,a0 ; skip R channel slice DBF d7,nextleft ; R channel pass MOVE.W (sp)+,d7 ; slice counter MOVEA.L (sp)+,a1 ; output buffer MOVEA.L (sp)+,a0 ; input buffer ADDQ.L #2,a1 ; R channel samples LEA 16(a0),a0 ; skip L channel LMS state MOVEA.W (a0)+,a2 ; loading LMS history MOVEA.W (a0)+,a3 MOVEA.W (a0)+,a4 MOVEA.W (a0)+,a5 MOVE.L (a0)+,d2 ; loading LMS weights MOVE.L (a0)+,d3 nextright: LEA dequant(pc),a6 ; pointer to lookup table ADDQ #8,a0 ; skip L channel slice MOVE.L (a0)+,d0 ; the first half of slice ; MOVE.L (a0)+,d1 ; the second half of slice SWAP d7 BSR.S slice ; decode slice SWAP d7 DBF d7,nextright MOVEM.L (sp)+,d2-d7/a2-a6 RTS ;============================================================================== ; Decodes QOA slice of mono/stereo stream. ; Registers usage: ; d0,d1 - slice ; d2,d3 - LMS weights (updated) ; d4 - residual sample, quantized, dequantized, scaled ; d5 - predicted sample ; d6 - scratch register ; d7 - not used (slice loop counter) ; a0 - not used (input data pointer) ; a1 - output data pointer (advanced) ; a2,a3,a4,a5 - LMS history (updated) ; a6 - pointer to 'dequant' lookup table (modified) ;============================================================================== slice: ROL.L #8,d0 MOVE.B d0,d4 ANDI.W #$00F0,d4 ; scale factor in bits 7:4 of d4 ADDA.W d4,a6 ; select lookup table row ;extract 9 residuals from d0, r[0] is in position already MOVE.W #8,d7 ; can't MOVEQ, upper half in use BSR.S DecSamp ; now the first bit of r[9] is in d0:0, pull two bits from d1 move.l (A0),D4 ADD.L d4,d4 ADDX.B d0,d0 ADD.L d4,d4 ADDX.B d0,d0 ADD.B d0,d0 MOVE.W #0,d7 BSR.S DecSamp MOVE.L (A0)+,d0 ROL.L #4,d0 ; extract 10 residuals from d0 MOVE.W #9,d7 BRA.S DecSamp ; (ab)use RTS at end of DecSamp ;============================================================================== ; Decodes a single sample. 3-bit encoded sample is in bits 3:1 of register d4 ;============================================================================== DecLoop: ROL.L #3,d0 ; decode residual sample using lookup table, store in d4 DecSamp: MOVEQ #$E,d4 AND.W d0,d4 ; extract encoded sample in d4 MOVE.W (a6,d4.w),d4 ; decode with lookup table ; calculate predicted sample, store in d5 MOVE.W a5,d5 ; history[-1] MULS.W d3,d5 ; *= weights[-1] SWAP d3 MOVE.W a4,d6 ; history[-2] MULS.W d3,d6 ; *= weights[-2] ADD.L d6,d5 MOVE.W a3,d6 ; history[-3] MULS.W d2,d6 ; *= weights[-3] ADD.L d6,d5 SWAP d2 MOVE.W a2,d6 ; history[-4] MULS.W d2,d6 ; *= weights[-4] ADD.L d6,d5 ASR.L #6,d5 ASR.L #7,d5 ; predicted sample in d5 ; add predicted sample to reconstructed residual with clamp to ; 16-bit signed range, store in d5, code by meynaf from EAB EXT.L d4 ADD.L d4,d5 CMPI.L #32767,d5 BLE.S noupper MOVE.W #32767,d5 BRA.S clamped noupper: CMPI.L #-32768,d5 BGE.S clamped MOVE.W #-32768,d5 ; update LMS weights, reconstructed sample in d5, decoded ; residual in d4 clamped: ASR.W #4,d4 ; scale residual signal down MOVE.W a2,d6 BMI.S h4neg ADD.W d4,d2 BRA.S h3 h4neg: SUB.W d4,d2 h3: SWAP d2 MOVE.W a3,d6 BMI.S h3neg ADD.W d4,d2 BRA.S h2 h3neg: SUB.W d4,d2 h2: MOVE.W a4,d6 BMI.S h2neg ADD.W d4,d3 BRA.S h1 h2neg: SUB.W d4,d3 h1: SWAP d3 MOVE.W a5,d6 BMI.S h1neg ADD.W d4,d3 BRA.S update h1neg: SUB.W d4,d3 ; update history vector update: MOVEA.W a3,a2 MOVEA.W a4,a3 MOVEA.W a5,a4 MOVEA.W d5,a5 ; store output sample MOVE.W d5,(a1)+ ADDA.W sampoff(pc),a1 DBF d7,DecLoop RTS ; not very effective, should be stored in some register once registers ; usage is optimized sampoff: DC.W 0 dequant: DC.W 1, -1, 3, -3, 5, -5, 7, -7 DC.W 5, -5, 18, -18, 32, -32, 49, -49 DC.W 16, -16, 53, -53, 95, -95, 147, -147 DC.W 34, -34, 113, -113, 203, -203, 315, -315 DC.W 63, -63, 210, -210, 378, -378, 588, -588 DC.W 104, -104, 345, -345, 621, -621, 966, -966 DC.W 158, -158, 528, -528, 950, -950, 1477, -1477 DC.W 228, -228, 760, -760, 1368, -1368, 2128, -2128 DC.W 316, -316, 1053, -1053, 1895, -1895, 2947, -2947 DC.W 422, -422, 1405, -1405, 2529, -2529, 3934, -3934 DC.W 548, -548, 1828, -1828, 3290, -3290, 5117, -5117 DC.W 696, -696, 2320, -2320, 4176, -4176, 6496, -6496 DC.W 868, -868, 2893, -2893, 5207, -5207, 8099, -8099 DC.W 1064, -1064, 3548, -3548, 6386, -6386, 9933, -9933 DC.W 1286, -1286, 4288, -4288, 7718, -7718, 12005, -12005 DC.W 1536, -1536, 5120, -5120, 9216, -9216, 14336, -14336
@Don_Adan, post #32
@Krashan, post #34
@Krashan, post #35
slice: MOVE.L (a0)+,d0 ; the first half of slice ROL.L #8,d0
@Don_Adan, post #36
@Krashan, post #37
DecSamp: MOVEQ #$E,d4 AND.W d0,d4 ; extract encoded sample in d4 ; MOVE.W (a6,d4.w),d4 ; decode with lookup table move.w (a6,d4.w),A5 ; decode with lookup table ; calculate predicted sample, store in d5 MOVE.W d1,d5 ; history[-1] MULS.W d3,d5 ; *= weights[-1] SWAP d3 MOVE.W a4,d6 ; history[-2] MULS.W d3,d6 ; *= weights[-2] ADD.L d6,d5 MOVE.W a3,d6 ; history[-3] MULS.W d2,d6 ; *= weights[-3] ADD.L d6,d5 SWAP d2 MOVE.W a2,d6 ; history[-4] MULS.W d2,d6 ; *= weights[-4] ADD.L d6,d5 ASR.L #6,d5 ASR.L #7,d5 ; predicted sample in d5 ; add predicted sample to reconstructed residual with clamp to ; 16-bit signed range, store in d5 ; EXT.L d4 move.l A5,D4 ADD.L d4,d5 MOVEA.W d5,a5 ; with sign-extend to 32 bits CMPA.L d5,a5 BEQ.S clamped TST.L d5 SPL d5 ; ??FF positive, ??00 negative EXT.W d5 ; FFFF positive, 0000 negative EORI.W #$8000,d5 ; 7FFF positive, 8000 negative ; update LMS weights, reconstructed sample in d5, decoded ; residual in d4 clamped: ASR.W #4,d4 ; scale residual signal down
@Phibrizzo, post #40
DecSamp: MOVEQ #$E,d4 AND.W d0,d4 ; extract encoded sample in d4 MOVE.W (a6,d4.w),d4 ; decode with lookup table ; calculate predicted sample, store in d5 MOVE.W d1,d5 ; history[-1] MULS.W d3,d5 ; *= weights[-1] SWAP d3 MOVE.W a4,d6 ; history[-2] MULS.W d3,d6 ; *= weights[-2] ADD.L d6,d5 MOVE.W a3,d6 ; history[-3] MULS.W d2,d6 ; *= weights[-3] ADD.L d6,d5 SWAP d2 MOVE.W a2,d6 ; history[-4] MULS.W d2,d6 ; *= weights[-4] ADD.L d6,d5 ASR.L #6,d5 ASR.L #7,d5 ; predicted sample in d5 ; add predicted sample to reconstructed residual with clamp to ; 16-bit signed range, store in d5 ; EXT.L d4 ; ADD.L d4,d5 move.w D4,A5 add.l A5,D5 MOVEA.W d5,a5 ; with sign-extend to 32 bits CMPA.L d5,a5 BEQ.S clamped TST.L d5 SPL d5 ; ??FF positive, ??00 negative EXT.W d5 ; FFFF positive, 0000 negative EORI.W #$8000,d5 ; 7FFF positive, 8000 negative ; update LMS weights, reconstructed sample in d5, decoded ; residual in d4 clamped: ASR.W #4,d4 ; scale residual signal down
@Don_Adan, post #42
; now the first bit of r[9] is in d0:0, pull two bits from d1 swap D0 move.w (A0),D0 lsl.l #3,D0 swap D0 MOVE.W #0,d7 BSR.S DecSamp MOVE.L (A0)+,d0 ROL.L #6,d0
@Don_Adan, post #44
; now the first bit of r[9] is in d0:0, pull two bits from d1 lsr.w #1,D0 move.l (A0)+,D0 rolx.l #4,D0 MOVE.W #0,d7 BSR.S DecSamp MOVE.L (A0)+,d0 ROL.L #6,d0
@Don_Adan, post #47
; now the first bit of r[9] is in d0:0, pull two bits from d1 moveq #1,D4 and.b D0,D4 move.l (A0)+,D0 add.l D0,D0 addx.b D4,D4 add.l D0,D0 addx.b D4,D4 add.b D4,D4 clr.w D7 bsr.b OnlyOnce rol.l #4,D0 ; extract 10 residuals from d0 MOVE.W #9,d7 BRA.S DecSamp ; (ab)use RTS at end of DecSamp ;============================================================================== ; Decodes a single sample. 3-bit encoded sample is in bits 3:1 of register d4 ;============================================================================== DecLoop: ROL.L #3,d0 ; decode residual sample using lookup table, store in d4 DecSamp: MOVEQ #$E,d4 AND.W d0,d4 ; extract encoded sample in d4 OnlyOnce: MOVE.W (a6,d4.w),d4 ; decode with lookup table ; calculate predicted sample, store in d5
@Krashan, post #37
@Don_Adan, post #49
@Don_Adan, post #50
Ewentualnie wylacz cache dla 68020/68030 i wtedy zrob testy obu wersji. Takie wyniki beda wtedy wiarygodne.Szeregowy użyszkodnik który sobie będzie chciał rozkodować plik (a niedługo i odegrać, player jest w robocie), a nawet np. programista gry, który będzie rozpakowywał dźwięki przy uruchamianiu, nie będzie przecież wyłączał cache. Ono po to dokładnie jest, żeby zasuwało szybciej. I to mnie interesuje, a nie jakieś akademickie rozważania o "zakłamywaniu wyników przez cache".
QoaToAiff jakisplik.qoa AUDIO:UNIT/0Co prawda ze względu na narzut AHI i niezbyt szczęśliwie w takiej konfiguracji rozwiązane buforowanie dźwięku, do płynnego odtwarzania 44,1 kHz stereo wymagana jest niebagatelna nadwyżka mocy obliczeniowej, więc to taka ciekawostka.
@Krashan, post #52
@Don_Adan, post #53
@Krashan, post #51
Procedura slice() ma 178 bajtów.
@Krashan, post #55
@Krashan, post #51
MOVEA.W (a0)+,a3
MOVEA.W (a0)+,a4
MOVEA.W (a0)+,a5
MOVE.L (a0)+,d3@Don_Adan, post #59
