@Benedykt Dziubałtowski, post #10
@Benedykt Dziubałtowski, post #13
@Norbert, post #19
@Benedykt Dziubałtowski, post #20
@Norbert, post #21
Wywal Voodoo z devs.
Amiga odpali sie w PAL
uruchom VooDoo z ikony.
W screenmode powinny pojawic sie nowe rozdzialki.
Jesli tak dzieje sie za kazdym resetem tzn ze Picasso zainstalowane jest poprawnie.
Przyczyny trzeba szukac gdzie indziej.
Sprobuj w s-s uruchomic tylko sterownik Voodoo ("wyremuj" linijki odpowiedzialne za start MONITORS)
@Norbert, post #24
C:CheckLMB
IF WARN
SYS:Prefs/FastATAPrefs
ENDIF
C:FastATA.driver QUIET
sys:c/wait 2
c:askmouse r
If warn then
sys:c/BootControl INSTALL boot BOOTDEV=DH0
else
EndIf
c:bppcfix install NIL:
;c:patchcontrol
c:stack 8192
c:blizkick kickfile=devs:rom3.1 extresbuf=50000 QUIET MODULE DEVS:MODULES/noclick prepareemul coldresetcard romfixes patchmath020
; $VER: Startup-Sequence_HardDrive 45.1 (25.11.00)
; Startup-Sequence for hard drive systems
;If Exists C:IDEFix
; C:IDEFix
;EndIf
C:SetPatch QUIET
PsdLoadModule DEVS:input.device QUIET ;Added by Poseidon-Installer
C:Version NIL:
C:AddBuffers NIL: DF0: 30
FailAt 21
C:MakeDir RAM:T RAM:Clipboards RAM:ENV RAM:ENV/Sys
C:Copy NIL: ENVARC: RAM:ENV ALL NOREQ
Resident NIL: C:Assign PURE
Resident NIL: C:Execute PURE
Assign NIL: ENV: RAM:ENV
Assign NIL: T: RAM:T
Assign NIL: CLIPS: RAM:Clipboards
Assign NIL: REXX: S:
Assign NIL: PRINTERS: DEVS:Printers
Assign NIL: KEYMAPS: DEVS:Keymaps
Assign NIL: LOCALE: SYS:Locale
Assign NIL: LIBS: SYS:Classes ADD
Assign NIL: HELP: LOCALE:Help DEFER
BindDrivers
C:Mount NIL: DEVS:DOSDrivers/~(#?.info)
C:LoadMonDrvs
IF EXISTS DEVS:Monitors
IF EXISTS DEVS:Monitors/VGAOnly
EndIF
C:List NIL: DEVS:Monitors/~(#?.info|VGAOnly) TO T:M LFORMAT DEVS:Monitors/%s
Execute T:M
C:Delete NIL: T:M
EndIF
SetEnv Language "english"
SetEnv Workbench $Workbench
SetEnv Kickstart $Kickstart
UnSet Workbench
UnSet Kickstart
C:AddDataTypes REFRESH QUIET
C:IPrefs
C:ConClip
Path NIL: RAM: C: SYS:Utilities SYS:Rexxc SYS:System S: SYS:Prefs SYS:WBStartup SYS:Tools SYS:Tools/Commodities
SYS:System/REXXMast NIL:
IF EXISTS S:User-Startup
Execute S:User-Startup
EndIF
Resident Execute REMOVE
Resident Assign REMOVE
C:LoadWB
EndCLI NIL:
@cholok, post #27
@Kitech, post #28
@Benedykt Dziubałtowski, post #29
