@MarcinAmiga, post #22
External Drive (DF1-DF3)
Replacing an external drive depends on the enclosure or cable being used. Amiga external drive enclosures usually include the circuitry to allow the Amiga to identify the presence of the drive. In this case the Gotek with S0 jumper is usually a straight swap for the old floppy drive. If using a passive cable such as this Ebay item then be aware that this identification circuitry is missing, but for arcane reasons identification will typically happen to work as long as the Gotek has an image mounted when the Amiga boots. If you are having problems with your drive being identified, see Forcing Drive Identification below.
High-Density Disks
Amiga Kickstart versions 2.05 and later support high-density disks with 1760kB formatted capacity. This enhancement required a customised (and nowadays expensive!) HD drive modified to rotate at half speed and emit a special ID sequence to the Amiga when an HD disk is inserted.
FlashFloppy supports this enhancement for 1760kB ADF images, but the high-density ID sequence must be explicitly enabled in FF.CFG.
If using an Amiga external drive enclosure, please bear in mind that the enclosure's interface board usually emits a fixed double-density ID sequence which will make HD images unreadable. In this case you must disconnect the enclosure's ID circuitry on its interface PCB:
Cut the PCB connection to external connector, pin 1.
Connect a jumper wire between internal connector pin 34 and external connector, pin 1.
Amiga hosts expect a drive ID sequence from external and Amiga-high-density drives on pin 34 of the floppy interface when the drive motor is disabled (pin 34 carries the Ready/RDY signal when the drive motor is enabled). In contrast, FlashFloppy's default interface mode (interface = shugart) permanently attaches RDY to pin 34, regardless of motor.
This default behaviour usually works fine:
Drive ID signalling is not a strict requirement for DF0
External drive enclosures often implement the drive-ID circuitry
A mounted disk image asserts RDY which happens to match the Amiga ID sequence for a DD drive anyway
However, there are a couple of cases where this default behaviour may not suffice:
Using high-density disk images (1760kB formatted capacity)
Using as an external drive with a passive interface cable, if FlashFloppy does not assert RDY during boot (eg. eject-at-power-on, no USB stick, or too slow to initialise)
In these cases FlashFloppy can be forced to emit the drive ID on pin 34 at all times, replacing RDY, by adding interface = amiga to FF.CFG.
When HD images are not being used, and when FlashFloppy is being used as DF0 or without problems as DF1-DF3, then it is best to use the default interface type (interface = shugart) as this gives more accurate behaviour on pin 34 in normal use while the drive motor is enabled. Exact emulation of pin 34 behaviour is not possible on unmodified Gotek hardware as the motor signal is not connected to Gotek's microcontroller. More accurate support, for modified or enhanced Gotek setups, may be implemented in future.
@snifferman, post #32
@Bociek78, post #33
step-volume = 0-20 (10*)
Speaker volume (connected at jumper JB) when drive heads are moved
@snifferman, post #30
